Verfasst am: 18.03.2009, 08:16 • Titel: AMB Transponder Reperatur mit schicken Design |
BRP Personal Transponder Repair Service
"New" AMBrc Personal Transponder repair service now available! Carbon look PT!
The Border Online Shop is happy to announce their exclusive AMBrc Personal Transponder repair service!
Broken PT wire? You need Carbon look? This is your chance!
We repair your AMBrc Personal Transponder and give it an fresh carbon look housing and a new wire with your choice of wire length ( max. 20cm/8inch ).
Please put the number(s) of your PT in the customer note of your order.
Send your PT with a copy of your order to The Border Online Shop and we will repair it. When the repair is complete we will send it back to you with your order.
Note: We repair only housing and wire. Before the repair the PT will be tested. In case the PT has another damage then housing and/or wire we will sent it back unrepaired. After the repair the transponder will be tested to be 100% sure it works correctly.
Quelle: www.buggy-sport.info _________________ gibt nichts interessantes in der Signatur |
