Team Orion Carbon Edition
3600 Race Spec
 Overview
(deutsche Fassung: hier klicken!)
Orions Carbon Edition 3600 Race Spec is part of a hardcase lipo series, that is well known since 2008's Nurnberg Toy Fair - we've introduced the whole range in this topic (german language).
The 3600 Race Spec is Team Orion's (to date) hottest hardcase lipo in the "Carbon Edition" series, with the entry level "Experience" (3200mAh) and the intermediate "3200 Race Spec" below. Compared to these, Orion's 3600 Race Spec features Kokam's latest "H5" generation of lipo cells, and according to Orion, it's good for currents of up to 90A (the "25C"-designation means currents of 25 times the pack's own capacity)
Orion's hardcase lipo comes with extras. Apart from an instruction manuals that tells you about the do's and dont's in lipo world, there are also two 4mm plugs for the pack's own power sockets supplied.
Additionally, for the bravest out there, the package also contains pre-wired Tamiya-style connectors. (Now talk about up to 90A running through those ;-) )
However, there's no 2mm plug supplied, but you'll need one for the small center terminal in case you want to load your lipo with a balancer which makes sure that the cell's voltages are equal. I'd strongly recommend using a balancer with lipos, and you can have a look at this little tutorial (german language) to see how to wire the battery charger leads for this.
All hyperlinks marked like this will be opened in a new browser window!
 Look & Feel
Team Orion's Carbon Edition series sports bulges on the bottom side, that imitate the profile of your good old nimh side-by-side pack. Protuding a mere 2,5mm, those bulges however aren't especially pronounced which means that the 3600 Race Spec will hook into the corresponding slots of the chassis, but you may need to rise battery posts a little. (though the lipo does not exceed the typical nimh-pack dimensions)
Additionally, you may want to work on the battery strap to clear the center balancer terminal. (more on that for later)
The 3600 Race Spec's protective (and gorgious looking!) plastic shell is made out of two halves which are glued to the cells inside, so potential hits are spread across the biggest possible surface.
Additionally, the two halves seem to be glued together as well, so there's no seam visible. The whole casing feels very sturdy and extremly well processed - something which you can expect from an 99,90 Euros (MSRP) lipo.
click here for a bigger picture
Here we see Team Orion's 3600 Race Spec being put into Tamiya's Durga DB01 Buggy.
Due to the small bulges on the underside, the battery sits a little higher than a conventional side-by-side pack.
So, the battery posts are raised for 2mm.
The piece of kitchen roll paper below is used to cushion the lipo so it's nice looking hardcase doesn't get scratched by debris.
Additionally, the dremel had a go at the battery strap so it clears the Race Spec's balancer port.
Cramped as most 4wd buggies are, the supplied plugs allow the leads to be soldered onto in a 90° angle to keep everything nice and flat.
 Performance
As we deal with Kokam's H5 lipo generation that we already reviewed in their 3200mAh form the strikingly similar performance doesn't come as a surprise:
Team Orions 3600 Race Spec unleashes an extreme punch from the get go. Towards the end of the runtime, the battery only dumps moderately fast which is typically for Kokam's lipos. I've seen lipos stalling faster, like some Trakpowers. In between, the pack delivers more power than current 1/10 offroaders can handle on most surfaces. Doubled up und wired in series, the 3600 Race Spec would even look good in bigger vehicles like Traxxas' E-Maxx an moderately powered bl-converted 1/8th scale buggies.
While loading Orion's Race Spec lipo, the advantage of 1p-configurations becomes obvious: the cells' voltages drift far less than in a typical 2p-configuration. Thís not only means less work for the balancer, but it also results in higher voltage until the battery dumps.
The table below shows Team Orion's 3600 Race Spec lipo compare to various other lipo batteries. The lower energy density (Wh/kg) is due the elaborate casing. The pack (together with Kokam's 3200 H5) features one of the highest measured effective capacity ratings of 98%. This is only surpassed by the 3200HD cells, which in fact are the predecessors of Kokam's current H5 generation, which themselves trade a noticably higher C-rating for a little less effective capacity.
offroad-CULT Lipo Benchmark
Lithium polymer batteries in comparison
» Kokam 3200 HD (2s1p)
200 grams 3300 mAh eff. capacity 103% 122 Wh/kg
» Kokam 3200 H5 (3s1p)
286 grams 3150 mAh eff. capacity 98% 122 Wh/kg
» Orion 3600 Race Spec (2s1p)*
228 grams 3550 mAh eff. capacity 98% 115 Wh/kg
» Stefans Liposhop SLS ZX-3700 (3s1p)
306 grams 3670 mAh eff. capacity 99% 133 Wh/kg
» Vampire Racing 4000 (2s1p)*
236 grams 4080 mAh eff. capacity 102% 128 Wh/kg
» Trakpower 4900 (2s1p)*
284 grams 4700 mAh eff. capacity 95% 122 Wh/kg
» Reedy 4900 (2s1p)*
287 grams 5100 mAh eff. capacity 104% 131 Wh/kg
» LRP Vtec 5000 (2s2p) (Ergänzung)
259 grams 4370 mAh eff. capacity 86% 123 Wh/kg
» Yuntong 5200 (2s2p)
285 grams 4790 mAh eff. capacity 92% 124 Wh/kg
Explanations:
  • Weight: measured weight including wires (non hardcase lipos) or without wires (hardcase lipos)
  • Effective capacity: measured capacitiy under typical 1/10 offroad use with 6,5 volts cutoff threshold.
  • Percentage value: effective capacity compared to the battery's nominal capacity.
  • Wh/kg: energy-density, derived from weight and effective capacity.
  • hardcase lipos are designated with an asterisk behind their name and configuration
 The Bottom Line
Not quite up to the latest nimh-offerings when comparing sheer runtime, Orion's 3600 Race Spec battery outclasses them with ease of use and zero maintainance (when loading with a balancer).
Compared to unprotected lipo batteries, the plastic cased Race Spec requires no additional protection while at the same time offering better compatibility to conventional battery compartments.#
Weighing an mere 228 grams, Orion's 3600 Race Spec is bound to shake up the weight balance in some rc-cars. Especially 2wd models are prone to this, so you might use a heavier steering servo or add some lead wheight in the front bulkhead to get the wheight distrubtion right.
Other than that, Orions lipo battery reduces a vehicles total weight up to 15 percent, which has quite an impact on acceleration and handling (if careful setup work has been done)
And if you're restricted to a minimum weight, you're still free to shift the weight balance more freely than with conventional batteries.
Because lipo batteries are quite a new thing to the rc-car scene, we'll refrain from a quantitative evaluation (1-10 points) for now. With long-term experiences still absent, that simply wouldn't be legitimate.
Text and pictures by Aaron Banovics
This article has been published on offroad-CULT on 03-23-2008.
Aktuelle Testberichte von offroad-CULT:
HPI-Racing SAVAGE FLUX - offroad-CULT test den ersten serienmäßigen Brushless Monster-Truck und zeigt auf mehr als 45 A4-Seiten, was die Community von HPI-Racings neuem Premium-RTR erwarten kann - weiter zum Testbericht!
LRP S8BX - ein ausführlicher Erfahrungsbericht über LRP electronics 1/8 Debüt! LRPs S8BX bringt zahlreiche innovative Features wie die adaptive Hinterachse oder ein neuartiges Bremssetup mit ins Rennen - doch wie praxistauglich ist das neue Konzept? (Einen ausführlichen Aufbaubericht gibt es hier!)
HPI-Racing E-Firestorm FLUX - RTR meets brushless & wir testen!
Im gewohnt dreiteiligen und ausführlichen Testbericht wird HPI-Racings Erstlingswerk in Sachen Brushless-RTR in all seinen Details genauestens unter die Lupe genommen.
Ansmann Racing Master-Smacker und Royal Flash - offroad-CULT lädt zum großen Doppel-Review!
In einem dreiteiligen Testbericht werden die neuesten Ansmann-Offroader ausführlich vorgestellt, miteinander verglichen und abschließend auf Herz und Nieren durchgetestet.
Losi Desert-Truck RTR - der heißersehnte 1/10 Stadium im Test!
Auf umgerechnet über 40 A4-Seiten stellt offroad-CULT Losis neuen RTR-Offroader vor und unterzieht ihn wie gewohnt knallharten Konstruktions-Checks und schonungslosen Tracktest-Sessions!
Günstig oder billig? Mit der neuen Dragster-Sport Brushless-Combo stößt Carson preislich in die Region von Bürstensetups vor. Doch ob die Performance eines Brushless-Systems würdig, oder ob der Griff zum Bürstensetup der Bessere ist, klärt unser Testbericht!
Einer für alle! GM-Racings Genius-Controller können Bürstenmotoren und bürstenlose Motoren mit und ohne Sensorunterstützung ansteuern. Was der hier gezeigte Genius 85 sonst noch so zu bieten hat, deckt unser Testbericht auf!
Was kann man von einem Modell zwischen Einsteigerbuggy und High-End Offroadmaschine erwarten? Wie schlägt sich Tamiyas neuer Durga DB01 im Vergleich zur Kyosho und Academy-Konkurrenz? Unser Testbericht klärt's!
Team Orion Carbon Edition 3600 Race Spec: Team Orions zur Zeit schärfster Hardcase-Lipo - auf dem Prüfstand!
INTERNATIONAL RELEASE available here!
Kyoshos Lazer ZX-5 Readyset ist eine preisgünstige Alternative zum Lazer ZX-5. Das RTR-Modell nimmt mit einem UVP von 269 Euro einen Platz in der sonst recht leeren Mittelklasse ein. Geht der Wunsch vom ambitionierten, leistbaren 4wd Rennbuggy für den Hobbyfahrer damit in Erfüllung... ?
Team Losis CR-Generation im Test, Teil 2: Auch der Stadium-Truck ist seit Kurzem als "CR"-Version erhältlich. Grund genug, den XXX-T cr zum offroad-CULT Härtetest vorzuladen und ihn auf Herz und Nieren durch zu checken!
Team Losis CR-Generation im Test, Teil 1: Im ersten Teil dieses Doppel-Tests lädt Losis XXX-cr zur Testfahrt ein. Fast 8 Jahre XXX-Plattform: Was hat sich geändert? Was wurde verbessert? Und was bringt's unterm Strich für den Fahrer? Hier geht's weiter zu unserem Testbericht!
Wettbewerbsbuggy goes RTR: Thunder Tiger bringt das bisherige Flaggschiff-Modell, den EB4 S3 in RTR-Neuauflage auf den Markt.
Was die RTR Ausstattung taugt und welche Figur der EB4 S3 RTR in der Praxis macht, klärt unser 58-seitiger Exklusiv Testbericht!
Hot Bodies neuer Allrad Racer: Mittelmotor, zweiteiliger Kardanantrieb mit Kegelrad-Getriebeboxen und Saddlepacks - so sieht das aktuelle 4wd Design-Dogma aus. Der Cyclone D4 setzt dieses auch kompromisslos um, doch wie macht er sich auf der Rennstrecke?
Stadium-Action zum Zweiten! Diesmal nehmen wir uns den Firestorm 10T von HPI Racing vor. Mit einer sympathischen Chassiskonstruktion und einem starken 3,0ccm Motor scheint er gute Karten zu haben -
aber reicht das für den offroad-CULT Härtetest?
INTERNATIONAL RELEASE soon
available!
Offroad-Einstieg um weniger als 150 Euro - ein guter Deal? Ist da nicht irgendwo ein Haken? Und überhaupt: Wie gut ist Ansmann Racings Smacker wirklich?
Der Budget-Buggy im offroad-CULT Test!
Reely / XTM-Racing X-Cellerator: Stadium Action zum Sonderpreis!
Ob sich der Stadium Truck lohnt, der hierzulande von Conrad Electronic vertrieben wird, stellen wir in unserem Testbericht fest!
available here!
Der Truggy im Kleinformat: Nach dem "Shark 18" 4wd Elektrobuggy im Maßstab 1:18 präsentiert uns LRP nun die Truggy-Version als Shark 18 Monster. Wir haben die RTR-Version ausführlich getestet!
available here!
Truggies liegen voll im Trend - klar dass Kyosho als eine der ganz großen Marken am 1/8 Offroad-Sektor dabei ist. Mit dem Inferno ST US Sports sollen vor allem Einsteiger angesprochen werden - auch wir haben uns angesprochen gefühlt!
available here!
Keep it small and simple - dass "Monstertruck" nicht gleichzeitig "Monstermäßig" kompliziert bedeuten muss, will Jamara mit der Track-Sau vorzeigen und sie uns als erstklassiges Bashgerät präsentieren. Wahrheit oder Marketing-Gag? - unser Testbericht klärt's!
Der Robitronic Protos ist ein 1/8 Verbrennerbuggy der Einsteigerklasse: um 400 Euro (UVP des Herstellers) bekommt man einen Buggy komplett mit Fernsteuerung, Motor und Verbrennerzubehör. Wozu der Protos taugt, klären wir in unserem 24-seitigem Testbericht.
noch mehr Testberichte ...
