wolfi CULT-Urgestein
Verfasst am: 26.11.2008, 08:51 • Titel: AE Brushless Conversion kit |
The new Team Associated e-Conversion Kit has been designed for the RC8, RC8T, and SC8 to be easily and neatly converted from nitro to electric power. The e-Conversion is a well thought-out, practical design thathas been engineered to work as an integral part of the chassis. Enjoying the awesome power and convenience of LiPos in your SC8, RC8 or RC8T has never been easier!
Rigid one-piece motor mount utilizes standard motor screw mounting pattern
• Large speed control mounting area raised off of chassis to allow for easy screw mounting of common speed controllers
• Speed control mounting area includes convenient switch-mounting boss
• Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray
• Molded Battery tray supports 7.4-14.8V battery packs with room for foam pads
• Accepts two ROAR-approved 1:10 scale size 7.4v LiPo battery packs (#703 Reedy LiPo 5000 PRO (2), #704 Reedy LiPo 5000 w/connector (2), #705 Reedy LiPo 3200 w/connector (2), #709 Reedy LiPo 5000 35C (2))
• New sealed receiver box for proper electronics placement
• Receiver, Servo, and battery tray remove from car in one piece for easy maintenance and cleaning
• Easy bolt-in chassis installation requires no modifications!
• Convenient wire routing keeps critical electronic wires out of drivetrain components and simplifies disassembly
• Includes two pinion gears (15T, 16T) and two spur gears (46T & 50T)
• Comes with all needed hardware to mount components onto chassis
• Motor, ESC, and batteries are not included
• RC8 conversion requires RC8e body #89523
Quelle: www.neobuggy.net
Wolfi _________________ ThunderTiger Racing - Team Austria |
othello CULT-Urgestein
Verfasst am: 26.11.2008, 19:15 • Titel: |
| Feine Sache, dass der nächste "grosse" Hersteller einen Elo-Umbau Satz anbietet. Auf den abgebildeten 1800kv Reedy Motor bin ich mal gespannt auch wenn er nicht zum Set gehört. Der Monster Max Regler wird wohl bald zum "standard". |
Buggy Bastler Werkstatt-Meister
Anmeldedatum: 08.09.2008 Beiträge: 153
Verfasst am: 26.11.2008, 20:07 • Titel: |
servus,
find ich genial, dass es von AE einen umbausatz gibt.
Sind die preise für umbausatz und elecktronick schon bekannt?
wann wird der zu haben sein?
MFG
Martin _________________ Mittglied im MSV-Burghausen
ASSO B44
Xray T2R PRO
Xray T3 2011
SPEKTRUM DX3 |
Verfasst am: 27.11.2008, 08:44 • Titel: |
sobald ich preise und verfügbarkeit habe - werd ichs hier posten.
gruß
Verfasst am: 23.01.2009, 09:00 • Titel: RC8E Limited Edition |
For a limited time only, Team Associated is offering the world-famous RC8 Factory Team kit including the eConversion kit (#80930) and Factory Team 16mm ‘Big Bore’ shocks, making for the ultimate electric-powered 1:8 scale buggy!
Available February 2009
RC8FT Electric Limited Edition Kit features:
• Factory Team threaded, hard-coated 16mm ‘Big Bore’ shocks with springs feature extra-large bladders for full volume compensation and 4mm gold shock shafts for durability
• Clear RC8e body #89523 included
• Rigid one-piece motor mount utilizes standard motor screw mounting pattern
• Molded battery tray supports 7.4-14.8V battery packs with room for foam pads
• Receiver, servo, and battery tray remove from car in one piece for easy maintenance and cleaning
gruß
mabu Offroad-Guru
Verfasst am: 23.01.2009, 10:15 • Titel: |
wie meinst du das mit baustellen??? versteh ich nicht ganz - ist doch alles dabei - oder ? (bin ja kein elofreak - aber so wie ich das sehe)
gruß
mabu Offroad-Guru
Verfasst am: 23.01.2009, 10:34 • Titel: |
| wolfi hat Folgendes geschrieben: |
Mein Fehler - ich meinte, wenn ich bei mir nicht so viele Baustellen hätte ( ok - 1 Modell lauft "nur" nicht ... ), würde ich ihn mir ja vll sogar leisten.
Ob Fepos auch passen werden? Leider fand ich noch keine Maße des Trays ... nur Beschreibungen, dass 4s Lipos passen sollen - samt Polstermaterial _________________
Brushless Revo
Xray XB8 goes Brushless
Serpent 950 BL
CRT.5 BL
Verfasst am: 23.01.2009, 11:00 • Titel: |
hi - da hab ich dann was falsch verstanden
folgendes hab ich zu den verbauten lipos gefunden:
Description: Reedy LiPo 5000mAh 7.4V 35C
The ultimate 7.4V competition LiPo battery has arrived! Reedy is proud to announce the release the all new 35C 5000mAh hard case competition LiPo battery. The high capacity provides more than enough run time for today’s on- and off-road competitions. But the best news is the battery’s 35C rating. The C rating determines the battery’s ability to deliver power efficiently. Reedy’s 35C rating delivers world-class power for all racing classes. Capacity and power are not the only great features of this battery. Socket-style connections provide low resistance for more power. Ugly and bulky high-resistance connectors are a thing of the past! A durable case helps protect the battery from damage and incorporates locking tabs as well as adhesive so that the case halves remain intact. Each battery comes with a charging harness that incorporates a balance connector for balance charging. LiPo battery technology continues to progress and Reedy is proud to bring improved performance to the masses. Specifications: Length: 138.5mm Width: 46.0mm Height: 25.0mm Weight: 295g Discharge: 175A continuous, 200A-225A burst Passes UN T1-T8 testing
ich hoffe, dass ist das was du suchst?
gruß
mabu Offroad-Guru
Verfasst am: 23.01.2009, 11:13 • Titel: |
Danke
Dh in einer Daumen x Pi - Rechnung gehen sich mit viel Glück
2 5s1p Side-by-Side aus oder mit ganz ganz ganz viel Glueck 2 4s Stickpacks. Das ergäbe ein nettes HV Setup  _________________
Brushless Revo
Serpent 950 BL
CRT.5 BL
