mannie Streckenposten
Anmeldedatum: 23.05.2008 Beiträge: 17 Wohnort: München
Verfasst am: 04.07.2008, 08:16 • Titel: NEU Traxxas SLAYER 4WD VERBRENNER |
Bin ja gerade im Traxxas Fieber - und seit heute morgen wird dort der neue SLAYER beworben - sozusagen der Nitro Slash.
Traxxas Slayer Pro 4WD Short Course Race Truck
Bilder verlinke ich erstmal keine - da ich nicht weiß ob ich das darf - meiner Meinung nach ein schönes Teil - aber ich bleibe ja nun bei Elektro!
FEATURES
Scale dimensions and looks of actual short course off-road race trucks
Chassis nerf bars absorb impact and support the body
Scale front and rear tube-style bumpers
45+ mph top speed out of the box; capable of 50+ mph with optional gearing
Larger 150cc Revo fuel tank extends run time
Digital high-torque, ball bearing steering servo delivers 125 oz-in & 0.16-sec transit time
Aluminum GTR shocks
New high-volume dual-stage air filter
Tight-handling progressive-2 rockers
Titanium-anodized chassis and chassis brace
Compact receiver and battery box with integrated personal transponder mount
Blue-anodized antenna crimp nut
Four channel micro receiver
Compact throttle servo mount with air filter support
Two-speed forward only transmission
Ultra-compact. Fewer moving parts
Low rotating mass for quick, high-revving acceleration
Constant drive engagement is smooth and instantly responsive
Sealed case protects gears & two-speed from damaging debris
Autoshifting two-speed is simple, reliable, & easy to adjust
Large diameter front disc brake
Mirror-polish Resonator™ dual-chamber aluminum tuned pipe
High-revving TRX® 3.3 Racing Engine for proven championship-winning horsepower and speed
Bigger piston and sleeve delivers extreme power
Consistent and smooth throughout the entire power band
Straight-through exhaust flow
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
Backed by Traxxas Lifetime Engine Replacement Plan
Torque-Control™ slipper clutch
Sealed limited slip front and rear differentials
Super-duty driveshafts
Sealed pivot ball suspension
Rubber-sealed ball bearings
Hex hardware
TQ™ radio system
Scale all-terrain front and rear tires offer superior on- and off-road traction
The tires include performance foam inserts and they come pre-glued on satin-finish wheels
ProGraphix® multi-colored painted body is available in red, blue, red/black, and blue/black
Slayer is backed by unparalleled Traxxas support and parts availability |
othello CULT-Urgestein
Verfasst am: 04.07.2008, 16:43 • Titel: |
Anscheinend mixen die auch gerne ihre Plattformen. Ich sehe da einen Revo mit Slash schwingen.  |
xpy Offroad-Guru
Verfasst am: 04.07.2008, 18:37 • Titel: |
| othello hat Folgendes geschrieben: |
Da hast du wohl recht.
Ich finde das schon hart, wie viele neue Modelle die in letzter Zeit auf den Markt werfen. Was kommt wohl als nächstes?
MfG xpy |
Verfasst am: 17.09.2008, 03:43 • Titel: |
Mittlerweile gibt es in den US auch Umbauten auf elektro (Kompatibilität zur Revo Plattform sei dank). Das Fahrverhalten wirkt aufgrund der schmalen Spur und des recht hohen Schwerpunktes eher bescheiden:
http://www.youtube.com/watch?v=XJ_vhkh-Toc |
mabu Offroad-Guru
Anmeldedatum: 05.11.2007 Beiträge: 590 Wohnort: Weiz
Xerophobie Werkstatt-Meister
Anmeldedatum: 29.08.2008 Beiträge: 236 Wohnort: Wien
Verfasst am: 17.09.2008, 17:47 • Titel: |
naja ... n bissl eine fehlkonstruktion ... den hauts ja bei jeder kurve !!!  _________________
Stolzer Besitzer eines Associated B4 Factory Team
RC-Chat beitreten: hier klicken |
Rotkehlchen Werkstatt-Meister
Anmeldedatum: 25.12.2005 Beiträge: 232 Wohnort: Aachen
Verfasst am: 17.09.2008, 18:32 • Titel: |
Der Fahrstil ist da aber auch nicht ganz unschuldig...
Dass die Räder unter der Karosse liegen gefällt mir optisch sehr gut - die Spurbreite leidet dann halt.
Wenn der Fahrer seinen Gasfinger etwas zähmt, würde der Wagen die Kurven auch besser fahren. Vor allem das ruckartige Beschleunigen macht dem Auto da ja zu schaffen. |
Servant of God CULT-Urgestein
Verfasst am: 17.09.2008, 19:58 • Titel: |
Denke mal der Umbau ist einfach zu übermotorisiert - Meinen Maxx hats mit dem Lehner auch nur rumgehauen, jetzt mit dem Feigao ist alles super Fahrbar.
Grundsätzlich ein geiles Teil! |
Verfasst am: 17.09.2008, 22:39 • Titel: |
Wobei der Slayer rein optisch wie ein Spielzeug wirkt, im Gegensatz zum Asso SC8, der weitaus mehr Scale Faktor mitbringt. Der Fahrer von dem E-Slayer aus dem Vid... kann sein daß er basteln kann, fahren kann er schon mal nicht  |
