Banana_Joe Kiesgruben-King
Anmeldedatum: 31.07.2011 Beiträge: 65
Verfasst am: 16.09.2011, 22:46 • Titel: HPI Mini Recon 1/18 |
HPI hat einen neuen 1/18er Monster Truck herausgebracht:
SHAFT 4WD SYSTEM
Heavy-duty 4WD shaft drive system to handle the High Torque RM-18 motor power
RSC-18 ELECTRONIC SPEED CONTROLLER
The High Frequency forward and reverse RSC-18 ESC provides all the power and control you'll need for the Mini Recon
RM-18 HIGH TORQUE MOTOR
High torque brushed motor gives the recon great performance both on and off the road
BALL DIFFERENTIALS FRONT & REAR
Super smooth ball differentials provide reliable power transfer
INDEPENDENT SUSPENSION
Fully independent double wishbone suspension front and rear provides total control and perfromance handling
OIL-FILLED SHOCK ABSORBERS
Factory-fitted long-stroke oil-filled shock absorbers soak up all terrain
BATTERY COVER
Covered battery for extra protection
SERVO SAVER
Twin point steering with integrated servo saver
FULL BALL BEARINGS
Fully equipped with ball bearings for a smooth, efficient drivetrain
COMPOSITE TOUGHNESS
Strong molded composite tub chassis, shock towers and suspension parts make the car nearly indestructible
MICRO BLOCK TYRES
Pre-glued high grip "Micro Block" tyres on chrome-plated 6 spoke rims
PAINTED BODYSHELL
Pre-finished and trimmed bodyshell, fully finished from factory with applied decals
COMPLETE RTR PACKAGE
Includes absolutely everything you need! Assembled chassis, pre-painted body, radio gear, 7.2V NiMH battery, overnight charger, 4AA batteries
Erinnert mich ein wenig an den Brama 18b:
Fluxfahrer CULT-Urgestein
Verfasst am: 17.09.2011, 00:16 • Titel: |
Ist aber eh besser, wer braucht noch mehr Autos die 1:1 von HB übernohmen wurden  |
Subotai Pisten-Papst
Anmeldedatum: 20.04.2010 Beiträge: 252 Wohnort: klgft
Verfasst am: 17.09.2011, 01:29 • Titel: |
...sieht nach einer leicht überarbeiteten Version des Maverick Atom XT Chassis mit Karo des Savage Nano Prototypen aus
Mango CULT-Urgestein
Verfasst am: 17.09.2011, 06:44 • Titel: |
sieht genauso aus, wie der "alte" asso rc18t (bis auf die Karo) (Kugel-diffs, Motor ganz hinten in der ecke, nicht einstellbare lenk-lgestänge, die servohalterung und Position, Die Dämpfer,sogar die plastik-diffausgänge und knochenwellen (oder sind das Cvds??)
Das ist meine Meinung dazu: wieder eine Kopie (ist aber nicht endgültig!!!)
Da finde ich den savage mini interessanter.
Leberwurst Werkstatt-Meister
Verfasst am: 17.09.2011, 07:51 • Titel: |
Der Truck ist ja schön und gut aber ich verstehe einfach nicht, was ein Kugeldifferential in einem Monstertruck zu suchen hat.
Und wahrscheinlich liefern sie den dann noch mit der 27Mhz Fernsteuerung. |
Verfasst am: 17.09.2011, 08:16 • Titel: |
scheint nicht so: auf dem empfänger steht 2.4 und ein quarz, geschweige den eine Buchse ist auch nicht zu sehen.
Verfasst am: 17.09.2011, 12:25 • Titel: |
| Mango hat Folgendes geschrieben: |
| sieht genauso aus, wie der "alte" asso rc18t |
Ähnlich, aber nicht gleich. Vergleich das von mir gepostete Bild mal mit dem Recon (sogar die Reifen sind ident)..
| Da finde ich den savage mini interessanter. |
Den find ich auch besser, kostet ja auch 3x soviel (vom Preis des Atom XT ausgehend)  _________________
